I street drive my car for now
But I run in a class that allows weight cutting up to 100 lbs, below factory listed weight for the car. Nobody really challenges me yet on this one. So What I do is balance it out. I add something, I take another item out. It is sort of a catch 22 thou. Why you ask, I have no windshield washer fluid so if I blast through a bunch of muck, I have to stop and clean the windshield. Maybe I need tear-offs for the windshield. Next round inner log reinforcements means I might remove head light motors. So I will have a couple gas struts, pop them up, and a latch on a string to keep them down. But you know I use head lights more than heat, blowers, hell I never touch that crap.
BTW, you forgot the loses that the AC system will place on your motor also. You might want to add a switch to disengage the AC pulley when you reach a certain throttle position. If it is one of the original 914 AC kits you will notice it. Heck I notice it on my Jetta TDI, and it has a lot more HP and torque than what you are running.
You could upgrade the compressor to a roatary style unit, much less parasitic drag. You will still notice it thou.....
