Hi Folks,
I'm slowly getting my car converted over to SDS efi, and all of the fittings on the hardware I'm using have aeroquip-style connectors. What I would like to do is install a aeroquip connector on the tank and run either braided or the new socketless lines to the back of the car in the same location as the originals.
Does anyone know if the fittings on the tank (70 914-6 if that makes a difference) are a standard size that maybe I could screw an already existing fitting to it? Does anyone know how much room there is for fuel lines where the pass through right now? IE what size O.D. hose can I use?
Any other suggestions for plumbing my fuel lines?
Sorry if I'm asking not too bright questions, I've sort of had this thrust upon me when I decided to go the FI route and I don't really know that much about it.
Thanks!
