Full Version: wheel/tire ?
rhodyguy
will the stamped steel wheels (the kind with the 4 raised "spokes") handle 195/60's without rubbing?
kevin
"i'll tell you later"
DNHunt
Yes I ran them before my Empies. It did rub some on the inside of the front wheel well toward the trunk.
Dave
rhodyguy
just on full lock tho? no prob on the rears? that's my consern.
kevin
DNHunt
Right
I kinda wish I still had the wheels. Might be a good temporary wheel for AX tires
Dave
Porsche Rescue
I had a '75 with those wheels and 195/65. No problems.
Also, I have often relied on Tire Rack's online specs for various size/brand tires and compared with their spec for whatever tire is on the car. If the tire I want is 1" wider I simply measure to see if I have a half inch inside and out. Method has worked so far.
Dave_Darling
...Just make sure they're the 914 steelies, not the Bug ones. Check for about 4 1/2" of backspace, or a little more.
--DD
boxstr
That's Paul Allen in that picture...
CCLINMSN
