At your request. On my soapbox:
IMHO AGM (Optima is one brand) batteries are vastly superior to "maintenance free" batteries. Soon everyone will be using AGM batteries.
"Maintenance free" batteries will vent anhydrous sulfuric acid into your 914 engine bay when ever they are charging. Add water and and you have sulfuric acid in your engine bay. If you overcharge one you may have sulfuric acid spewing all over.
AGM batteries do not normally vent sulfuric acid, even when charging. Overcharge one and you may vent sulfuric acid, you may even have sulfuric acid spewing all over.
So, buy a AGM and do not overcharge your batteries.
AGM batteries, in general, like to be stored at full charge, and have superior perfromance to comparable conventional batteries, including "maintenance free". Superior perfromance includes more cranking amps and longer life if kept near full charge.
Optima also has the YELLOW TOP, which is an AGM battery that has similar performance to a conventional battery and withstands repeated discharging better than a Red Top. Life appears to be similar to a conventional battery if abused in such a manner.
If discharges will be common you need a deep cycle battery. The Optima AGM battery in this category is a Blue Top.
So I recommend getting a Red Top and keeping it charged by driving the car, a battery maintainer, or just throwing a good charger on it every couple of months. Or getting a YELLOW TOP.
Excerpt from
Lead acid hazard assessment webpageWe often hear -"Oh we don?t need to worry about those batteries - they are maintenance free and leak-proof too!" The person in question here may be referring to a VRLA or Valve-Regulated Lead Acid battery. They could also be referring to a "gell-cell" or gelled electrolyte battery; possibly an Absorbed Glass Mat (AGM) battery or absorbed electrolyte battery. These common and erroneous, assumptions about maintenance requirements and leakage could lead to a disaster.
All of these battery types feature a sealed case; however, the physics of how each battery functions is significantly different. Valve-Regulated batteries are a type of sealed battery that, as the name implies, regulate the expulsion of excess hydrogen gas through a one-way valve or vent. VRLA batteries are often called captured electrolyte or capture mat batteries, they are sometimes called recombination type batteries. These names are indicative of the internal physics of the battery while the terms "vented" and "valve regulated" refer specifically to the mechanical device allowing the battery to expel excess gas.
VRLA batteries can contain significant amounts of sulfuric acid and they
do vent explosive hydrogen gas. Worse still, they are very sensitive to temperature and charge rate. If overcharged, VRLA batteries can go into internal thermal runaway and explode. Additionally, some case swelling is considered "normal" though excessive case swelling may indicate trouble. All this information can be confusing - suspect battery plants should be surveyed by a professional battery technician.
Gell-cell batteries are a sealed case type of battery which recombine
the hydrogen formed in the recharging process with free oxygen to form water which, in turn, keeps the cell "wet" or hydrated. The term "maintenance free" was coined by battery manufacturers in order to market recombination type batteries. Don?t be fooled!
Off soapbox.
