QUOTE(mharrison @ Oct 28 2003, 07:55 PM)
I have a set of 7" Cookies that I want to put under my fiberglass GT flares. What size tires will fit, and when I convert the lugs to 5-lug, (via a drill and stud) will I need spacers? If so, how thick and what length studs?
225/50 x 15 all around on 7" cookie cutters ...
1 1/4" spacer in the front
1 1/2" spacer in the back
no long studs for me, i have spacers with studs pressed in.
so, you bolt on the spacer using the original studs (spacer come with steel lug nuts to do so),
then bolt your wheel onto the spacer.
NOTE: i don't have redrilled hubs, i have real 5 lug back and front.
