QUOTE(Bleyseng @ Sep 25 2006, 05:52 PM)
Keep the retard vacuum hose connected to the back of the vac can on the dizzy.
If you don't have a small vac port on the throttle body thats above the throttle plate, just plug the hose for the vac advance.
For your high idle, get some PB Blaster and squirt a bunch of it into the AAR valves two ports. Let it sit and some more as the AAR valve is a rotary valve and it does rust abit and sticks open usually.
Check your timing, should be exactly 27 degrees at BTDC at 3500 rpms
Check your fuel pressure as that is at 29lbs not 32-35 lbs (too rich)
I meant for you to remove the dizzy and take out the advance plates an clean and grease them where they pivot on each other. The old grease drys up and sticks after its 30 yrs old.
hey bley
thanks for the quick reply.ok here are my #trottle body 039 133 067 vw
ECU 0280 000 037 and 022 906 021E
MPS 0280 100 007 and 311 906 051C
the ecu and the mps are from my old 1.7 L (bus engine) that froze up on me so i did the rebuild on the 2.ol with some parts from my 1.7 and bought parts from the club (throttle body)
I blocked off the vac advance and left the vac retard in place like you said.
let me know what you think. I will be on the site on Tuesday.
i will have to check my psi later with help from the mech who installed my engine.
thanks for the help have parts if you need some let me know. for you almost free or even free if we fix this with out me paying 95 bucks an hour for my mech.
Cheers
Andrew in the Soo and the only teener lover with in a 8 hour drive.Sucks to be me all alone up here except for you guys.
