Since a couple of people have asked I've decided to add some pics and dimensions of a rotisserie you can build for probably under 100 bucks! I'm sure it will hold at least 2500 lbs with the thickness of metal used but I wouldn't go any heavier than that, also the weight is what you and a couple of buddies can lift overcenter by hand. The only drawback is since the suspension is part of the rotisserie so you can only take one side apart at a time!!!
My CAD program crashed so I had to use MS paint!! Ha
