McMark
Sep 20 2006, 02:03 AM
I nabbed all those pictures. Good stuff. I'd love to get that motor.
bd1308
Sep 20 2006, 07:42 AM
WOAH
whats it say? I shoudl have listened more in german class.
Brian Mifsud
Sep 20 2006, 07:45 AM
I did the "BabelFish" translation, and the seller says everything which was originally CAD plated was redone. Sure looks nice.
I've never seen the "checkerboard" style pattern on any aircleaner, but my experience has been with the '72 1.7 and '76 cars I've owned. Is this a common aircleaner on '73-'74s? Or is this Europe specific?
anthony
Sep 20 2006, 08:25 AM
QUOTE(McMark @ Sep 20 2006, 01:03 AM)
I'd bet one of your motors are better. Most of this is easily reproduced with lots of elbow grease and spray paint. I do think the few cad plated bolts is a nice touch.
Dave_Darling
Sep 20 2006, 08:37 AM
I've owned one or two air cleaners like that. Seen more at swap meets and so on. I think they were 75-76 for the most part (or all of them?).
The 74 European owner's manual shows that style air cleaner for the 2.0 as well.
Yeah, I know--just adding to the confusion...
--DD
Bleyseng
Sep 20 2006, 10:28 AM
QUOTE(Dave_Darling @ Sep 20 2006, 07:37 AM)
--DD
Huh?,, the 75-76 ones have the EGR port above the throttle body clamp.
I have seen a few of the checkerboard ones too but thought they were the 73 ones.
bd1308
Sep 20 2006, 12:06 PM
euro 2.0s didnt have EGR AFAIK
DEC
Sep 20 2006, 01:22 PM
QUOTE(Brian Mifsud @ Sep 20 2006, 05:45 AM)
No its not Europe specific, I think it is a VW part.
All Porsche aircleaners for the 914 were plain
Cap'n Krusty
Sep 20 2006, 01:29 PM
QUOTE(DEC @ Sep 20 2006, 12:22 PM)
There were no VWs with that style FI, therefore no VWs with that style air cleaner. The Cap'n
p914
Sep 20 2006, 01:50 PM
Same air cleaner I had on my 75 2.0 now replaced with k&N
tod914
Sep 20 2006, 06:50 PM
Heres the babel fish thang..
Porsche 914 2,0L engine 100Ps, new appearance, identification letter GB, overhauls, with controller, engine relay, starter and transmission 914/11 (transmission does not overhaul). The engine can do rehearses runs and it the following parts was renewed: Connecting rod bearing, piston rings, valves (in and discharge opening), valve guides, valve springs, tappet protective pipes, cylinder staybolt (8x long and briefly) of rotary shaft seals crankshaft, gasket kit, suspension camp, distributor cap, verteilerfinger, circuit breaker, ignition cable and plug, spark plugs, air cleaner, oil filter, oil, pipe connection to 90%. Calculations for new parts and cylinder head repair available. The moreover the axial play of the crankshaft was again adjusted, flywheel again flat polished, clutch nearly newly. The Motorverblechung was sand-radiated and painted with 2K lacquer. Various parts were again galvanized and chromated yellow. Private sales - in accordance with new your-genuinly no guarantee. Dispatch on pallet possible, costs would have one with Ilox to erfagen, dispatch service for European Union would have one to determine.
Dave_Darling
Sep 20 2006, 09:08 PM
QUOTE(Bleyseng @ Sep 20 2006, 09:28 AM)
Sorry, I wasn't clear expressing myself.
I meant that the ones I had were 75-76 because they had the EGR port (blocked off in both cases, BTW). I don't recall if the other criss-cross pattern ones I've seen were early or late, but there's also a pic of one on in my 74 European owner's manual. Right across from the pic of the 1.8 with dual carbs.
--DD
TravisNeff
Sep 20 2006, 10:42 PM
My early 73 2.0 does not have the cris cross aircleaner - but I suppose it could have been swapped along the way.
jk76.914
Sep 21 2006, 05:23 PM
I picked up a cris-cross version brand new on eBay a couple of years ago. $10 IIRC. Intended to use it on my '76.
Anyway, the port for the crankcase vent hose is too small for the '76 arrangement. Still trying to figure out how to work it in.
Jim
