QUOTE(Pat Garvey @ Sep 20 2006, 06:23 PM)
Yeah, I don't get it. One the most tidy engines I've seen on a 914, but the cleaner is "different". Don't know where it camefrom, but it loks like it should be there. Yeah, I know, it's not right ut someone spent some money.
Or.....is it some derivation I don't know about? hmmmm
I know that this is an old post which I came across in researching here for my early 73 2L resto, but I thought that I'd add to the info base here for others.
My 73 914-2.0 (still marketed in Fall 1972 as a "914S" when sold new on 11/9/72 in CA), has the very same "Diamondback" EFI Air Box as shown on the first photo in this post, as shown in the photo of my much dirtier one below. My 914 has been stored in my garage on blocks since 5/85 & I haven't started the clean-up process yet - so it's dirty!
"Diamondback" style embossing on 2.0 EFI "Air Box" for GA000424 in VIN 4732901954:Click to view attachmentAlso note that there is a difference of crossbars & diamondback embossing on mine - vs. the one above, so even the complexity of that changed. Did anyone get an engine number for the one above back in 2006, to try to place it in the production sequence??
Here's what I believe that the embossing style progression on these Air Boxes" was - both from my own observations & from checking with my long time mechanics at Hans Imports in Huntington Beach, CA. FYI - Hans was factory trained on the 914s before he came to the USA & started his business in the early 70's, & he was a local legend for keeping 914s & VWs in good working order around Orange County, CA. The embossing is mainly to make the thin sheet metal more rigid, & perhaps somewhat for aesthetics early on as well.
Initial 2.0s with "Diamondback" embossed pattern 1972 to +/- mid or late 1973 production
Mid-run 2.0s with "Crossbars" embossing pattern (as in the 2nd post) started with late 73s or 74s
Later 2.0s had the "Smooth-top" boxes perhaps starting with the 75 GC engines
I'm not real sure about the dates & time span for each, but the time order of the progression is right. Their reason for doing so was apparently cost, because each was a progressively less complex stamping to non-embossed top, which of course each are progressively cheaper to create the stamping dies for production.
That was one of many steps Porsche was taking over the years to keep their advertised "teaser" starting price down on the 2.0s (& 1.7s/1.8s too).
Along those lines - as you all may already know - the 73 2.0 basically came "fully loaded" with the then "new" Fuchs 2.0 Alloys, full compliment of the Appearance & Performance Groups' sets of options - all for the 2.0's base price, & often a few other options, dealer installed radios, etc. at additional cost. However, starting in 1974 they made progressively more of the "standard 2.0 upgrades" from 1973 MY, into add-on options at additional price until virtually everything was optional by the end -
even though most all of the 76 2.0s still came loaded! It's just that they could advertise the 2.0s as "starting at $xxxx" - but just try finding one in later years at that base price! I know, because I looked at new MY 76 2.0s in Fall 75 before I bought mine used, plus I didn't like the fat black bumpers, lower power, more weight, etc. - as compared to the 73/74 2.0s.
So I ended up buying my 73 2.0 at 38 months old used for $4500 in Dec. 75 (after Hans had inspected it & given it his seal of approval) - instead of a new 75/76 for more $$$$ & ended up long term with a better car which holds/appreciates value better than any other 914 except the 914/6's. ...wow was that a lucky stroke!!!!
BTW - before I focused on 914s, I had done extensive research on performance, reliability, features/etc. & value retention between the MGB/MGC, Triumphs, Austin Healys, 240Z/260Z 912s & 914s. It came down to 240Z vs. 914, with the Z's only retaining +/- 70% of their new value, & 914s 80+%. It would be interesting to see how that has turned out long term today!?
Hope this adds something for everyone!? ...& not just my rambling on to myself!?
...and I sure hope I can get mine to look as good as that one above, when I get it all up to speed later this year!
