How Is the pully below secured? It Just sits and dosen't spin does the loss of that pump cause the motor to overheat
Mueller
Sep 24 2006, 01:22 PM
Oakley???
you're not too far from me
I'm in Antioch off of Hillcrest....
There is a pulley that attaches to the fan which turns the smog pump, good chance the pump is frozen....I think the adjustment is on the smog pump...
Mueller
Sep 24 2006, 01:24 PM
oh yea, the pully on the fan has a rubber isolator to transmit the power, sometimes these can break...I might have an extra one and an extra smog pump...
Brando
Sep 24 2006, 01:30 PM
What year car is it? You may not even need the pump or any other smog equipment.
BMITCHELL
Sep 24 2006, 01:33 PM
His VIN starts 476. Thanks to the Gov he needs to smog it in Cali.
lilly4324
Sep 24 2006, 01:55 PM
QUOTE(Mueller @ Sep 24 2006, 12:24 PM)
lilly4324
Sep 24 2006, 02:00 PM
okay Bust does that loss maake it overheat and by the way it is a 76 2.0
Mueller
Sep 24 2006, 02:06 PM
it should not cause it to overheat whether the smog pump is working or not...
with engine OFF, can you turn the smog pump over by hand? Is the belt still attached?
