My humble opinion is...
If you are a concourse oscar myer.... Disregard this post.If you need to save money and have more time than dollars.
The following MAY serve you. (Has me)
Here is one more CHEAP AND SOLID OPTION.
Thats is using Rust Oleum primer and Rust Oleum PRO-Paint.
note: READ THE DIRECTIONS. DO EXACTLY WHAT IT SAYS OR GO TO THE MANUFACTURERS SITE TO GET EXACT DATA FOR APPLICATION.
That goes for any paint you aren't familiar with.
The best part is: You can buy all your painting supply's at Home Depot.
No matter where you are, you can buy touch up paint.
It's stupid cheap. And touch up is relatively EASY...
If you can borrow or rent a high end HVLP or LVLP gun. You will be way ahead of the game.
You will also need oil and water seperators. GOOD ONES...!!!!!!!!
or you will be in a world of shit.
And it comes in many colors. Like Black...!!!!
NOTE: If you want flat black. Just add a compatible flattening agent to the paint.
There are many threads on the net of exactly how to apply, thin, sand and polish these particular paints.
Most of the fellas have no idea how good this paint is. Much better than you would expect. And how durable it is.
Many a round "D" round car has been painted with this paint.
And you can clear coat it and really make it shine... Yes really.
Can I make it look like a high end paint job. Pretty dam close. It's all about step sanding. (clear coat is needed for best shine)
Race cars don't need a clear coat. Too much hassle to touch up.
(And I am lazy)
NOTE: You can use 3M finishing film on a DA instead of blocking the final coat. It's fast and ya don't use water.Then again. If you are going flat black.
(Rat Rod Look)
Ya might NOT want to sand it smooth anyway. Cause the sanding will start to polish the paint.
The other option is John Deere tractor paint.
Also known as IMPLEMENT PAINT.
Can buy it at any farm equipment parts store.
(Caterpillar yellow rocks..!!!)
Many of the flat black rat rods you see at shows and in magazines are painted in John Deere flat black. It's cheap. And sprays easily. (if thinned correctly)
Works like the Rust Oleum paint. And is even more durable, easy to apply and can withstand the odor coming from Aarons feet or Zs ass. Now that staying power my friend....!
Note: Both of the above paints are fairly high in Solids. (I know)
Therefore if you try to spray a tac coat, then immediatly lay on a thick coat. It will run worse than Howard running from Slits on a casadores night in the woods.
So you have to build coats.
3 coats will cover that Teener better than a piece of duct tape over Britt's keyboard hand.
And in fact. That is exactly what i would do, (and have done)
if I had a track car or an average street car.
Especially if I didn't want the car to rust.
And someday down the road. Put a high end paint job on the car.
Keep it simple and repairable.
So thats my .02 worth.
Clayton
When all else fails.
Auto Body 101 ForumsNow.... Back to the cave......................
