Ok, I’ve got some 69 S front struts that have the 3.5-inch brake rotor spacing. I also bought Koni yellow struts and the adapters from Paragon to use in Koni's in the struts. I’m not going to use either one so I’m going to sell. OK, here is the question, the shocks are new never used but are in the struts with oil or antifreeze. Should I sell as a “set” or separate?
Brad Roberts
Oct 30 2003, 01:39 PM
I would seperate them. You'll end up getting more money for the "pieces".
B
fiid
Oct 30 2003, 01:44 PM
Would these casings fit the 944 brakes in described in the other thread??
Brad Roberts
Oct 30 2003, 01:45 PM
Yes.
B
J P Stein
Oct 30 2003, 01:58 PM
Mr. Hanna....Iza't Mark?
Do me a favor and weigh one of them S calipers...I'm starting to sound like a broken record.
Brad Roberts
Oct 30 2003, 02:00 PM
Dont do it Mark. JP is old and crusty.. he wants you to weight them because he cant see the scales small numbers.
B
J P Stein
Oct 30 2003, 02:10 PM
Hay.....Iffin' I flip up my trifocals and get up real close I can see all kinds of stuff.
Being old & crusty has it's drawbacks, but the alternative is worser.
Brad Roberts
Oct 30 2003, 02:16 PM
I'll be lucky if I make it to old and crusty.
B
MJHanna
Oct 31 2003, 05:52 AM
QUOTE(J P Stein @ Oct 30 2003, 01:58 PM)
I would but don’t have any “S” calipers I was going to use Carrera Calipers on this project (which I could weight but you really don’t care about them.)
