QUOTE(bd1308 @ Sep 27 2006, 12:56 AM)
I figured such piece could be extruded through a die....
seems simple enough in profile. most liekly molded in the one piece config, but since theyre NLA, gotta look at other easier options.
I think it would be simple to get a profile of the seals and extrude each inidividually.
My understanding is that the seal is made up of five different parts. I believe that is the top, two sides and two parts that connect the sides to the top. The top and sides look like they could be extruded peices. The other two look to be molded. Then they are all connected prior to vulanization??
The top has an embedded metal part that I think function as a way to hold the seal to the windshield frame. Creating a true repro of the OEM part is expensive due to the embedded metal part and multiple parts that make up the complete seal.
Doesn't Mittelmotor offer a repro version of the OEM part (without the metal insert)? I looked on their website and see it listed for 165 euros (assuming I am looking at the right thing). I also seem to remember reports that people are having problems installing it (it is tight and they end up tearing it during installation). Also I seem to remember reading that it might not be in stock. Mittelmotors site doesn't indicate if an item is in stock or not.
