QUOTE(ddog87 @ Sep 28 2006, 11:40 AM)
So I looked through the links about the trany linkage and thought I would just try to see if the thing had reverse period. This is a side shift tranny. As I am looking up at the bottom of the transmition the shift link that goes into the tranny, should be up and towards the rear correct???? I'll get a picture> Thanks
Reverse should be same direction as 2nd and 4th and that sound correct
Have someone shift the gears while you lay under the transmission to get an idea of how the linkage moves, you can also see if you have any major slop and see if the rod going into the transmission is moving enough. You can remove the long linkage bar and move the shift link that goes into the transmission by hand.
If you plan on keeping this car, I recommend getting the exploded views drawings available in the resource or classifieds section....it would have saved you some trouble by showing the "bent" linkage....
