QUOTE(vertigo @ Sep 28 2006, 09:35 AM)
Sorry, yes both lights on cluster flash. The blinkers on outside remain correct. About 3 month ago I did change the return cog for the blinker, but it has worked fine until 3 days ago.
I had similar problem. Replaced a flasher bulb (right front) maiking sure I had correct 2 filament bulb and that started a cascade of issues. Cleaning contacts on bulb socket helped keep fuse from blowing, but after that, both lights would flash on tach, while outside lights would flash correctly. Replaced flasher relay and that seems to have solved the problem
