QUOTE(maf914 @ Sep 28 2006, 12:03 PM)
The Haynes manual says 7.4 pints or 3.7 quarts. I always use four quarts. No problems.
The manual also indicates 2.1 pints to fill from the lower mark on the dipstick to the upper mark. Are you sure you have the correct dipstick for your engine?
it looks like the dipstick they show in the manual..except the manual only has 2 notches....after running the engine, the level comes to the middle notch, but you say I should add another 1/2 qt ...right?
