Dave's "Good News/Bad News" joke on this--
The stock rubber bushings are vulcanized to the trailing arm. You cannot replace them (with new stock bushings!) without buying a new trailing arm.
There are aftermarket bushings.
They squeak.
There are some things that can be done to keep them from squeaking.
They only work for a while.
You can re-do them periodically.
It's a pain in the butt...
...OK, you can have grease channels cut into the aftermarket bushings and a Zerk fitting put on them, so you can re-grease them periodically. That's less of a PITA than disassembly and reassembly every year or two. They still need to be fitted carefully.
You could, on the other hand, go to a roller-bearing setup. More $$ to buy, more work to install, but they don't make noise and they let your suspension move the way it's supposed to. They may transmit a bit more NVH (Noise, Vibration, Harshness) into the cabin than the soft rubber bushings do.
There are options, but they all have bad points as well as good ones.
--DD
