QUOTE(Cap'n Krusty @ Sep 28 2006, 08:01 PM)
Loosen the oil filter until there's a gap. Crank the engine (with the spark plugs out and the point wire disconnected) until oil comes out of that gap. Tighten the filter, clean up the mess, crank it 'til the light goes out. Bingo! Oil pressure.
BTW, it's BAD practice to start the engine without having cranked it for oil pressure. You just put a BUNCH of wear on the bearings. The established procedure is to crank it with the plugs out until the oil light goes out, then maybe a few more seconds. After that, you can install the plugs and run it at 1500 RPM or more at a steady speed for 20 minutes, shut it down, let it cool, and adjust the valves.
The Cap'n
Thanks for your reply ... I had primed the filter and cranked it for a few brief trys with the coil wire off. Pump was also packed with light grease to help prime. Have pertronix... no points. I didn't think just cranking the engine would register on the gauge or make the light go out. We all learn from our mistakes.
Does anyone know approximately how long it takes to get oil pressure by loosening the oil filter?
If a oil pressure control valve is stuck, could it cause no oil pressure. I do know that there is a small drilling in it.
Does anyone know if the stock oil pump is prefered over the Heavy duty one or if the HD has any known problems?
Everyone has a opionion and I am ready to listen to any of them.
I wish I had found the club earlier. Hopfully I will soon be able to share my 914 experiences with others. As for now my knowledge of small sports cars lies mostly with "Z" cars and Triumphs.
