QUOTE(jsteele22 @ Sep 29 2006, 09:50 AM)
Brant,
I'm a little confused. Are you saying that on higher-HP cars new washers are not the way to go ? Or just that even using new washers is not enough ?
Jeff B,
When you say "serrated" washers, is that the same as the stock ones ? I seem to recall that they were smooth but wavy. Are you using something different ?
Mr. Steele,
the factory washer is actually not wavy.
its a schorr (sp) washer... aslo called serrated.
I replace mine when they are apart.
shops will NOT reuse them even one time.
(I admit that on occassion I have reused them and always am nervous and retorque them at 100miles)
my comment was more about the gaskets than the washers
I've had new washers come a little loose at 150hp.
I think racing adds a huge complication to this... the heat, the abuse, the constant on and off of full throttle.
AJRS told me that the washers come loose as a result of the gaskets.
and that as hp and load increase it becomes more of an issue.
thus they discovered that leaving the gasket out solved the problem
this is a proven solution which is track tested at 300rwhp. I'm sure those cars are using NEW washers AND leaving the gaskets out.
I don't know if Dr. Evil wants to become a washer salesman or not.
but for my race car I bought 45 new washers from him last month.
I will change the washers each time I touch the CV's when ever possible.
brant
