toddmr
Sep 28 2006, 08:16 PM
I have a 1975 914 1.8 and am experiencing the following:
1. Transmission leaking fluid.
2. high-pitched screeching when the car is started.
The screeching doesn't seem to change with the engine speed. If I rev the engine to higher RPM, the screeching stays pretty much constant.
Looking under the car, it appears that tranny fluid wasn't just leaking, but spraying.
The last time I drove the car before getting the screeching sound, the clutch felt different. It's hard to explain, but it kind of had a "gritty" feel to it.
I'll get it into the shop as soon as I can, but would like some help/clues on diagnosis, so I can at least brace myself for what might be headed my way repair-wise. And I can start working on my wife so she won't freak out over the bill.
If additional information would be helpful, let me know and I'll post it. May be able to get some photos under the car as well if that would be helpful.
grantsfo
Sep 28 2006, 08:28 PM
QUOTE(toddmr @ Sep 28 2006, 07:16 PM)
Sounds like a transmission main shaft seal gone bad.
toddmr
Sep 28 2006, 08:31 PM
Any idea how much it'll cost to remedy?
Dr Evil
Sep 28 2006, 08:34 PM
Yup, main shaft seal probably contaminated your clutch disk as well (the gritty feel).
Tranny fluid shouldnt really "spray" as it is not a pressurized system. Look to see if the rear engine seal is not gone as well.
The screetching is odd. If it were from the tranny or engine it should vary with engine RPM. Are you sure it is not coming form a blower fan or something?
grantsfo
Sep 28 2006, 08:37 PM
Depends on where that noise is coming from and whether the clutch disc is messed up from tranny oil. Seal is cheap all the other stuff can get expensive. If youre going to drop the tranny and havent done a clutch for awhile you might as well just do a new clutch. 914's are tough call as when you drop the tranny you may find more.
Dr Evil
Sep 28 2006, 08:38 PM
QUOTE(toddmr @ Sep 28 2006, 10:31 PM)
Oh ya,
Cost varies. Seals are about $10, they will have to drop your tranny to get to your clutch and check it all out. Clutch disk is a bit (not sure on price).
Check GPRparts or pelican for parts and prices.
TROJANMAN
Sep 28 2006, 08:39 PM
the seal is about $15
the repair is pretty easy if you do it yourself, just time consuming
toddmr
Sep 28 2006, 09:16 PM
I've done a fair bit of work on cars. Tell me if you think I should be able to accomplish this.
I have:
replaced the steering rack on a volvo 740;
replaced the brake booster, master cylinder, bent and installed brake hard lines on the volvo 740 and VW GTI;
rebuilt brake calipers, removed and installed new rotors, wheel bearings, etc. on my GTI;
I'm generally not afraid to give something a shot if I have a chilton's or equivalent, or better yet, photo play-by-play from a good website.
I'm trying to figure out if this is something realistically possible for me to do, or if I would just end up crying a lot, shipping to car to Auto Atlanta, and crying some more when the bill arrives.
toddmr
Sep 28 2006, 09:17 PM
All these photos were taken under the passenger side.
mihai914
Sep 28 2006, 09:25 PM
With these two articles you should be able to handle it.
Engine DropClutch ReplacementNot that hard to do even for a first time, the only danger is that while you will be in there you'll want to fix this and that and will end up like many people here including myself having a jackstand queen!
grantsfo
Sep 29 2006, 02:45 PM
Change of diagnosis. That appears to be leaking differential seal.
toddmr
Sep 29 2006, 03:45 PM
Is the differential seal easier or harder than the rear transmission seal? Does it make sense to do both at the same time?
bondo
Sep 29 2006, 03:48 PM
A bad release bearing will squeal right before it falls apart (ask me how I know) and also really messes up the pedal feel.
Dr Evil
Sep 29 2006, 05:13 PM
Good call Bondo.
You need to reseal your tranny. The diff seals are much easier to do, but require you to remove the CVs, and output flanges (19mm bolt). Your intermediate plate gasket is leaking as well.
Basically, you should by a whole seal kit, read my thread on how to pull your gear stack, and replace all of the seals your self. You can do it, we can help. If you get hung up, just ask questions.
Seal kit = $40 and requires tranny drop
