I need some input on the clutch fork travel. I recall the spec being 20 mm but how to measure it was never clear to me.
I haven't changed the flywheel or pp, only put in a new 6 spring disc since the other one was contaminated from a good mainseal leak.
During the repair I found a couple of things missing such as the plastic spacers around the throw out bearing and the clip that is supposed to hold the fork to the ball cup, everything is fixed now and much tighter than before.
Here are some pictures of the fork travel to the point where the TO bearing makes contact with the PP, is it good?
I have no reference point so I don't know if I need more or less...
Thans for the help.
