Are the 1.7 - 1.8 and 2.0 valve covers all the same...What about other options, like VW bus etc...Should I just look for Type IV engine covers...
2-OH!
Aaron Cox
Oct 31 2003, 04:22 PM
i think they are all the same. there are some aftermarket bolt on versions, but the consensus of the group is that these arent as good. (mount to rocker studs )
Jake Raby
Nov 1 2003, 12:07 AM
They are all the same.......Aftermarket ones suck.
BarberDave
Nov 1 2003, 05:06 AM
Not that I would ever be put in a position to disagree with Jake. BUT! My stock valve covers leaked like a sive, anything I did to remedy the problem didn't work. So i bought a set of cast Aluminum aftermarket ones. That bolt to the rockers, no more leaks . Being cast they were thicker and more ridged. Or maybe my thirty yr. old valve covers were just worn out. Any way it worked for me. Dave
Jake Raby
Nov 1 2003, 11:44 AM
Most people do not know that valve covers have a right and wrong way of being installed..
The right way is with the VW logo upside down.
Most of the time I can dyno an engine with stock covers and no sealant all day and never havea single drip.
Some covers are warped and will never seal off.
The reason I don't like the bolt on covers is the way they attaach. They expect a piece of grade 2 hex bar that has been threaded to hold the tesnion of the rocker assembly and the cover with a 7mmx1 thread pitch.
Poor design.
I use some carbon fiber valve covers, and have great results. they work with the stock bails.
Nov 1 2003, 01:50 PM
QUOTE(Jake Raby @ Nov 1 2003, 09:44 AM)
upside down, eh? (in my best homer simpson voice)
now that would explain a few things Andy
Jake Raby
Nov 1 2003, 03:21 PM
Yep, upside down. a Type I ONLY goes on one way....guess what, logo is also upside down.
Aaron Cox
Nov 1 2003, 03:22 PM
that seems stupid on vw's behalf.... common sense would tell you to put them right side up
