I'm a 914 newbie with a 73 2.0L and I have several issues:
1) the wires to the light between the seats has dropped somewhere down there so I need to retreive it to plug it back in. How does that panel come off (Vertical panel between the two seats). Does it require removal of the seats?
2) there is some clucking sound, like something being buffetted by the wind, and hitting the firewall back there somewhere. Occurs at about 60mph with windows down, top off. How does the panel between the seats and the door come off? Again, does it require removal of the seats?
3) While I'm in there, seat belt retractors are not retracting as they should. Any trick to repairing these?
4) Dashboard gauges. How do those come out? in my older 911s, those were simply held in by friction. Is it the same in the 914? I need to pull the speedo to repair the odometer.
5) Console gauges. Do you have to get those out from behind (and thus require removing the console to get to them)? I and need to pull the temp gauge to repair the light, and the clock to r/r it as well.
Thanks for any advice on these topics.
DG
73 914 2.0l
97 993 Targa
