BUMP for the Georgia Contingent..!!!!!!!!!!!!!!!!!!!!!!
This may WELL NOT be your problem. Cause this is a worst case scenario. And your bike is too kewl for this to happen.
But if all else fails.................................................
It was the bike "THUMP" while starting that brought back an old memory. I heard and had the same occurence on a guys car that had a rebuilt engine built by a guy named Stromberg.
Couldn't keep the timing straight. it would move all over ther place. It also had a new dizzy.
And during the first half secong of the engine starting. (when it started)
The engine would make this terrible mechanical sound until it was running for second or so. Once it was running. it was kinda ok.......
The sound was like two gears getting parked against each other and then braking free. this all took like a milisecond to make this sound. it shook the whole car. But just for a piece of a second. if that makes sense.
It was a THUMP.
In this case. it was a chipped distributor gear on the crank. The idiot builder had used a fucking sledge or something to put it on. And had chipped the crank timing gear. it ended up killing the dizzy. Had to pull the engine apart and replace the gear.
Check your dizzy as per Mueller. By the way.
Maybe one of the Georgia Boyz can give ya a visit and help ya figure this out...........
Regards,
Clayton
