QUOTE(neo914-6 @ Oct 1 2006, 11:27 AM)
QUOTE(SirAndy @ Oct 1 2006, 11:22 AM)
QUOTE(neo914-6 @ Oct 1 2006, 01:43 AM)
Where do you get hinge shims?
never ...
do what any *good* bodyshop does ...
Andy
and that is...?
provided your body is straight and doesn't have "custom" bondo body lines around the doors (ask me how i know
), here's what i learned from a top-notch body shop:
open door, grab the end of the door and pull/push *slowly* until the door lines up perfectly!
basically, you massage the metal of the front door jamb until the door is lining up perfectly, using the door itself as a lever.
most of the time, if there's no body damage involved, sagging or otherwise out of alignment doors are a result of people putting their own weight on the doors when they're open, effectively bending the front door-jamb.
all you have to do is to un-bend it, using the same "method" ...
has always worked great for me!
Andy
PS: btw. same goes for the windshield hoop. people tend to grab the top corner of the windshield to "lift" themselves out of the car, thus bending the frame down.
bodyshop fix: bend it back the other way.
PPS: one thing the owner of said bodyshop told me: we never do this with the customer around.
they tend to freak out when they see how we do the "straightening".
