Howdy!
Just got back from a tour in Iraq this past Friday night. Spent some time getting to know the family again, and now I need to get my 72 back on the road.
Just before I left (like hours before I left) I ran into a throttle cable problem--The cable housing frayed and came apart at the curve just past the firewall, causing too much friction to pull the linkage. Being a bicycle guy, that should be easy to fix (I think). I pulled the wooden pedal board in preparation for installing a new cable -- that was a pain. Is is just as hard to get back on? Is it a necessary part?
Also, just before I left, I installed a bosch hot start fix kit, and it started fine. I'm stationed in 29 Palms, and it get's freakin' hot here. Now, it won't crank at all. Tried to jump it, and still nothing. I hear the electronics in the engine compartment coming on, but nothing at all from the starter. I'm going to clean all the contacts after church today. I suspect the starter, but it worked fine when I left in Feb. Maybe a bad connection somewhere.
Finally, one actual question: The car has been sitting since Feb. It's got dual carbs--is there anything special I need to know before I get it on the road again? should I invest in some carb cleaner before I even try to fire it up?
It's great to be back!
Scott
MSgt---USMC!
