Is there any way to remove this screen without pulling the gas tank and removing the air box?
I'm in the process of sanding for paint and I slid card material under the grille, on top of the screen so I don't have to remove it now. But I'm really not comfortable with it for painting since the card material won't slide under as good side to side as it does front to rear. Since this is a pretty visable area I want it to come out right. If anyone has a slick way to easily remove it I'd appreciate knowing. If there's no easy way, I was considering cutting it out for paint and replacing it later - anyone done this?
