QUOTE(computers4kids @ Oct 1 2006, 04:35 PM)
Could anyone help...I am a little confused how to connect a tow vehicle's lights to my wiring of my 914. Dan (Almaden Valley) supplied the bottom schematic, but I'm still unclear...he has made refrences to "BL" "T" "T" and "BR" on the schematic.
I have attached the 914 talight wiring diagram for further clarification.
I am using a Roadmaster kit that uses 4 of the 2in 1 out diodes.
I know this should be simple!!
Mark
Right side.
Bl-brake left #54 on your 914 diagram remove wire from terminal #54 and put into input side of diode. The other input lug on that same diode gets the green wire from your new harness. You make a new lead to go from the out put side of the same diode to now connect to terminal #54.
This light will now function as your left turn and brake light.
Tail light left- connect the second diode by taking the wire off of the "58" terminal on the tail light. now connect that lead onto the second diode input side along with the brown wire from the towing wiring harness.
Repeat for corresponding terminals and diodes on the Right side.
hope this helps.
