I replaced all the seals I could get to without droppin the engine this weekend as far as oil movement is concerend. But I still have a fairly major leak somewhere around the oil cooler area. It is bone dry when I park, but as soon as I get some oil movement it starts to become a smoke machine really good for Halloween, not so good for daily driving. The PO had just the HE tubes running without shrouds so I think that I always had this leak, just nothing for it to fall onto. I do notice a drip that hangs off of my oil filter and also one on the push rod tubes. I thought those were coming from the oil cooler leaking. I guess not or I installed the seals wrong?!?!
What else is on the left side of the engine that would leak over the oil cooler area and do you have any suggestions on how to trace an oil leak tha only seems to happen with the car running. I am not a big fan of lying under a running engine with Hot oil coming out
I am fairly certain it is not the oil pump since the fron of the engine appears dry. The motor appears to have been rebuilt at some point I believe.
Thanks
73 2.0 Stock Djet FI
SSI He's (just added)
