Let's pull the engine, sheet metal and head. Then see what we have.
It would help to look at the sealing surfaces so we klnow whasss up.
I would be afraid to simply torque the heads. As we don't know the condition of the threads and the nuts, or the washers for that matter. If there is any crusty stuff ANY of these parts. WE CANNOT get an accurate torque value. NOT EVEN CLOSE. Then you are back to where you started. Or maybe worse.!!!!!!!!!!
When ya want me to show up at your house to do this??
You and me bro, And maybe we can get Skline to show up so I am not the only old fart at your crib. I am sure you will get help for this if you ask.
Primarily because you are so dam selfish and never help anybody.
You name the date. I check my calendar. We geter done.
If ya need a head surfacing thang. I can get it done in a day or two.
AND we can check your rings, etc......
As I am writing this. I was thinking. (God help us, for I know not what I think)
We could hook up a leak down tester to your engine and define the cylinder pretty easily. This assumes it leaks when cold. I think my leak down is at Sklines. Or it got stolen with the stuff from last year. I furget.
Either way. I'm down to help.
C
