QUOTE(trekkor @ Oct 3 2006, 01:55 PM)
This car normally gets driven about 400-500 milles a year
That sounds like you are using less than two tanks of gas per year. So if you haven't driven it for a year, the gas could very well be closing in on two years old depending on your recent milage
Drain the gas, replace the fuel filter and clean out the carbs.
You need to drive it more.
I thought I was bad, I only drive about 200 miles per month.
KT
I guess I'll drain the gas, check the idle jets, and pull the intake manifolds and check for leaks.I have been working a lot this year, 6 days a week, haven't had time to drive it much.Plus I'm working on a 71 to do a V8 conv.too many projects not enough time.In Md. we don't have a 12 month 914 season more like 7 or 8.I don't believe I let my carbs gum up.I'll only let it happen once, already bought the stabuilt fuel stablizer.
