dflesburg
Oct 3 2006, 07:55 PM
need to install a line lock for a parking brake,
What size fittings are on our brake lines?
jd74914
Oct 3 2006, 08:08 PM
don't install a line lock for a parking brake
they don't hold the pressure well enough. after a while your car will role away.
the brake lines are 5/16IIRC tho
Aaron Cox
Oct 3 2006, 08:44 PM
they bleed off pressure and bye bye car.....
why not do the johnman 911 ebrake or get a willwood spot caliper setup from marty or renegade
jd74914
Oct 3 2006, 08:57 PM
I'd go for a cable operated wilwood stop caliper.
John
Oct 4 2006, 09:40 AM
Go to your FLAPS and take a piece of brake line with you. The stock lines are a euorpean bubble flare and the fittings are metric threaded.
You need to take a sample with you to be sure that it matches up. Your FLAPS will have generic straight lines that you will need to bend to fit.
We have already discussed a line lock, but if that is what you are going to do, that is what you are going to do. They will work for a while. I prefer the 911 e-brake solution, but that is my own biased opinion.
Make sure you park in gear.
jus tmy $0.02
Aaron Cox
Oct 4 2006, 09:43 AM
hijack - whats your relation to each other? brothers? father-son?
John
Oct 4 2006, 10:27 AM
QUOTE(Aaron Cox @ Oct 4 2006, 07:43 AM)
He's my older bro.
flesburg
Oct 4 2006, 12:44 PM
dflesburg,
Or you could just get some wheel chocks.
Harbor Freight probably has them, or you could carry a couple of bricks with you.
You should also put the car in 1st gear.
Or you could get a chain and padlock and always park next to a big sturdy post and chain the car to the post.
John
Oct 4 2006, 12:48 PM
Aaron,
Before you hijack again, that would be my Dad.
dflesburg
Oct 4 2006, 01:25 PM
what is FLAPS?
dflesburg
Oct 4 2006, 01:28 PM
As I stated many times,
The only purpose is to pass the inevitable "CHIP's" side of the road safety inspection... Grrr.
John
Oct 4 2006, 01:37 PM
A FLAPS is a:
Friendly
Local
Auto
Parts
Store
