QUOTE(bd1308 @ Oct 3 2006, 10:44 PM)
hell yeah that would a screaming /6
not good for gas though
I hope you are not serious........
But if you are, here's the reason you would NOT want this.
It would work like the Pinto/Weber 2bbl on a type IV.... The carb would run cold and the fuel would drop out of suspension before it got to the cylinders. Mebbie that is what the oil line under the carb is for??
Plus, it doesn't look like it would flow too well, the plenum is chunky and poorly fabricated, and a fuel/air mix doesn't like turning corners without the fuel dropping out of suspension. That's the reason that Porsche used Solex, and later Weber carbs. There is no place for fuel to drop out of suspension when the whole intake run is almost perfectly straight down.
