I seem to remember the issue where your engine was locked. What caused that? Anyone?
Aaron Cox
Oct 4 2006, 11:19 AM
hydrolocked....
car at an angle.... on tow dolly... filled cylinder with fuel.....drained bowls of carbueretors.. (they established that it never went into gear...)
put it in a forward gear and rolled it backward a few strokes......
started right up
Eric_Shea
Oct 4 2006, 11:22 AM
Did he change the oil after that??
Aaron Cox
Oct 4 2006, 11:25 AM
dunno....
not a TON of fuel in the bowl but you are right.. probably a good idea.... couple ounces in the bowl.... some got past the rings.... some stayed inthe cylinder... then went out the exhaust valve...... hmmm.....
few ounces / 9 qts or so of oil - probably not a huge issue....
