QUOTE(ThinAir914 @ Oct 4 2006, 10:51 PM)
QUOTE(Lou W @ Oct 4 2006, 10:28 PM)
I used this instead of POR-15, it turned out really good, but it too will yellow unless it has a top coat;
Rust BulletAny idea how much of this it takes to do a rear trunk floor? 200 square feet per gallon sounds like you could probably get by with a pint.
I did both the entire engine bay and rear trunk (about 2 or 3 coats worth) with a quart of POR-15 and had a little left over. So I'm sure a pint would be enough.
It dries very glossy if on a smooth surface. Parts of my floor pan actually look like they have a pool of water on them because of the POR-15 paint look. But when the paint is exposed to the sun it loses its glossy-ness and gets flat black looking.
Where does one buy Por15?
/end
I found some at an automotive paint supply store.
