randyt914
Oct 4 2006, 05:58 PM
thanks for the help. Is pulling one out of a junker possible or can they even be found?
john rogers
Oct 4 2006, 06:07 PM
I am not sure what you mean by "windshield rubber"? On 914s the windshield is held in with tape and has soft aluminum trim over the outside held on with plastic clips. On my race car as do many others I use a rubber seal instead of the aluminum trim but the windshield is still glued in.
randyt914
Oct 4 2006, 06:13 PM
QUOTE(john rogers @ Oct 4 2006, 05:07 PM)
yes that is what i wanted is a little help in the aftermarket rubber dept. i have never done a winshield so is this "rubber" common? Thanks alot.
GWN7
Oct 4 2006, 06:27 PM
take a look at this thread........
http://www.914world.com/bbs2/index.php?show...p;hl=windshieldIt will leed you to other threads about the same subject.........
Mueller
Oct 4 2006, 06:38 PM
There is no "set" part to use or vehicle from which to referance, people have tired different parts thru the years....I know some people have has success with Honda CRX(?) windshield rubber....
Twystd1
Oct 4 2006, 06:39 PM
PM Slits,
I think he might what you are looking for.
C
The chrome trim is held by plastic clips. When you remove your trim, the winshield is free and will be loose on the frame. Behind the windshield on the window frame is a rubber ribon which is continous around the perimiter if the windshield. The seal is usually dry and won't be much good once you rmove the windshield. Some have substituted it with butile tape and reinstalled everything with the chrome trim and others glued the windshield in with an after market rubber trim around the windshield. Whatever you use behind the windshield, it needs to be water tight and solid. Butile tape is illegal if used alone to hold the windshield in place. You are better to use glue as on Ford vehicles for this water tight seal. Ther original seal is osbsolete and pricy if you find one.
Bartlett 914
Oct 4 2006, 07:04 PM
You might try Brian (736conver). Either he has this or knows where to get it.
john rogers
Oct 4 2006, 07:36 PM
Ahhh as I thought. When I had the windshield guys put in a new one this past winter they had some rubber seal that fit perfectly. I have no idea what car it was specific to but the guy had several sizes when he came by. Try a good company local to you and they should know how to fix you up.
randyt914
Oct 4 2006, 07:39 PM
thanks for all the insight and links.. im at 6500 feet and it snows alot here. im gonna try a fun teener with studs on the rubber all the way around.
