QUOTE(tracks914 @ Oct 5 2006, 07:18 PM)
Why would the pump have to be different? Could I not just run the 3rd line back to the tank return line???Besides that I want to put a 6 or a Ruby 4 into this car. I will need a different fuel pump anyway but do sixers put their fuel pumps up front or do they like it in the rear???
I dunno know, maybe 'cause you said:
Can anyone post some good pix so on this resto I can move it to the front and make it look original??
It wouldn't look original with the totally wrong pump and plumbing now would it???
You should be able use the stock fuel pump for just about any fuel injected /4 or /6 motor you install, if you go with carbs, you'll need a new pump for sure.
Most fuel pumps "push" fuel better than "suck", so closer to the tank is a good idea...
