Series9
Oct 5 2006, 09:01 AM
Luckie's car may go this direction.
MoveQik
Oct 5 2006, 09:05 AM
Do you have the car yet? If so let's see some pics my brotha!
Ferg
Oct 5 2006, 09:12 AM
Nope I have it still
, I may even give it a bath this weekend
it's still dusty from the PO.
Joe, I have the old excellence with the 1.8T race car article, remind me to give it to you when you guys come.
Ferg
Series9
Oct 5 2006, 09:19 AM
We should be getting the car on Monday.
I'm currently bored in Baltimore, so I'm crunching some numbers on getting Luckie 220hp/Motronic for the best price while staying in the Porsche/Audi/VW family.
The 1.8T seems to fit the bill.
TROJANMAN
Oct 5 2006, 10:13 AM
joe,
i have a contact for 1.8t engines in denver
he's a vw salvager
we talked about building me one, once
Series9
Oct 5 2006, 10:17 AM
QUOTE(TROJANMAN @ Oct 5 2006, 10:13 AM)
joe,
he's a vw salvager
Do you know what they're going for?
TROJANMAN
Oct 5 2006, 10:30 AM
$2,100-$2,800
Depending on model year
andys
Oct 5 2006, 10:43 AM
QUOTE(TROJANMAN @ Oct 5 2006, 09:30 AM)
$2,100-$2,800
Would that be with the transaxle? The VW/Audi trans would be an exceleent upgrade to the 901.
Andys
TROJANMAN
Oct 5 2006, 10:48 AM
joe,
the earlier motor would be best.they are cheaper, and would fit better than the later motors. You would need to use the 901, and transaxle adapters are available.
andys
Oct 5 2006, 11:29 AM
Well, I understand why you'd want to stay with the 901, but the VW/Audi 5 speed is very good. I think someone posted once that the CV's will bolt up to the flanges as well. BTW, the model 012 VW/Audi transaxle is the same as boxster 5 speed. Depending on the VW/Audi trans code, the same ratio's are available. At least you wouldn't have to buy the adapter and clutch assembly, so you'd save $800-$1000(?) right there.
Andys
Series9
Oct 5 2006, 11:35 AM
The adapter is $500. How much is an 012 tranny?
TROJANMAN
Oct 5 2006, 12:05 PM
I am pretty sure it's a different transaxle than the boxster, but i could be wrong.
For the heck of it, a tranny will run you about $300, but i don't think there is any compatibility with the 914. I think the shifter comes out of the wrong place on the VW tranny, and won't line up for use.
Mueller
Oct 5 2006, 12:18 PM
It was Sonu (914-1.8T) that did a streetable 1.8T conversion with the Audi/VW gearbox.
Series9
Oct 5 2006, 12:21 PM
QUOTE(Mueller @ Oct 5 2006, 12:18 PM)
Was there a thread?
andys
Oct 5 2006, 01:29 PM
QUOTE(Series9 @ Oct 5 2006, 10:35 AM)
Don't forget that you'll still need to add the cost of the flyheel and clutch to that $500.
Andys
Series9
Oct 5 2006, 01:40 PM
QUOTE(andys @ Oct 5 2006, 01:29 PM)
Andys
I visited KEP today (online), it says $500ish for everything but the clutch.
neo914-6
Nov 22 2006, 05:41 PM
QUOTE(Series9 @ Oct 5 2006, 10:21 AM)
Was there a thread?
Joe,
Here you go:
1.8T in 914He sold the complete 1.8T engine to install a 2.7TT...
okieflyr
Nov 22 2006, 06:00 PM
I've got a full auto-x season on my 1.8t conversion so far, and I'm pleased.
I converted the car using a VW 03 aniv 1.8t, and mated it to a reinforced 901.
The engine mgt consists of the factory ecu w/custom flash to get around the theft deterent, and gives 200hp/230tq. The torque comes in low around 1800 RPM, and will light up the r-compounds. I've used the stock body mounts as well. I've posted a few pics here in the past. KB
Brad Roberts
Nov 22 2006, 06:04 PM
Joe,
go with the Audi/Boxster tranny.. hydraulic clutch.. cable shifted.. you can mount the shifter easily on the tunnel with little to NO headache.
Not sure if you fab a lot.. but the tranny mounts are not difficult.
The first time I drove a 1.8T.. I knew it would work perfect for a 914.
B
okieflyr
Nov 22 2006, 06:46 PM
I'm watching for an Audi a4 trans at my local yard, that I can get a Quaiffe set up for. I know that the 901 has limits in the auto-x enviroment, but so far I'm not abusing it[b]yet, and there is enough torque to start from 2nd gear. KB
QUOTE(Brad Roberts @ Nov 22 2006, 07:04 PM)
Joe,
B
neo914-6
Nov 23 2006, 12:50 AM
From what Sonu has done, the Audi gearbox is the most cost effective and you can connect the sensor if you use Audi e-speedometer. I'd use an earlier engine before they changed to e-throttle. The Boxster cable shifter can be adapted to the Audi box since they are very similar.
No one to my knowledge has mated a 5 speed Boxster gearbox to an Audi 1.8T. At $1.5-2k they are hard to justify relative to $500 Audi boxes. The Boxster gearbox has the same Audi 2.7TT bolt pattern but there are differences in the clutch, CV's, axle lengths, and e-speedo...
