yeti
Oct 6 2006, 09:50 AM
Hello,
just have a short question. Will a harness bar like this
http://www.914world.com/bbs2/index.php?show...;hl=Harness+barfit in a 914 with fixed passenger side?
Thanks and have a good time.
Yeti
Joe Bob
Oct 6 2006, 10:02 AM
Fit? Yes.....but the backpad will need some mods.
yeti
Oct 6 2006, 10:14 AM
Hello,
are some picture available? Do I have to cut the passenger "headrest"
Thanks
Aaron Cox
Oct 6 2006, 10:36 AM
PM joe sharp...
he has a custom harnes bar that goes overthe non movable headrest
Brad Roberts
Oct 6 2006, 12:07 PM
Please read your competition seat belt install booklet. You will find that they DO NOT want you to mount/run your shoulder straps ABOVE your shoulders. They are not designed to mount like this.
B
spunone
Oct 6 2006, 01:58 PM
So Brad you saying you need to have the harness bar below sholder height to work prop?
Aaron Cox
Oct 6 2006, 01:59 PM
below = spine compression in crash
i think you want 0 to 15 degrees up angle....
too much above your shoulders and they dont hold you in, in a rollover
spunone
Oct 6 2006, 02:02 PM
And if your spineless?
15degree up ?should that be downward?
Aaron Cox
Oct 6 2006, 02:13 PM
0 degrees - level with your shoulder...
15 degrees up is the max you should go...
depends on which way you are looking at it.... sure.. 15* downward angle toward your shoulder....
yeti
Oct 6 2006, 03:31 PM
Hi, I know about the problem with the shoulder straps. So what is the proper solution? My car is a street car, not a race one and I want it to look as stock as it is possible with the modification. So I eithe cut the passenger side headrest and install a harness bar or I leave it stock?
Thanks Yeti
Brad Roberts
Oct 6 2006, 03:39 PM
Drill holes for eye bolts in the firewall just below your shoulders towards the middle of your back and clip in a new set of comp belts.
Honestly,
I dont know which is worse? Running around on 35yo stock seat belts or having your competition belts not work properly in a crash??
I mount mine below my shoulders like the instructions call for and I dont get too concerned about my passengers.
B
Aaron Cox
Oct 6 2006, 04:23 PM
also....
when you drill the holes inthe firewall... you need to use the big washers.. AND they need to be mounted to bare metal.... not thru a soundpad etc....
designed for ZERO compliance.....
metal to metal on both sides... cut soundpat/and backpad to fit OVER THEM... not sandwiched by them
spunone
Oct 6 2006, 04:36 PM
Thanks fellas now I get it
