Here's another list, but I think the data are similar. Common to both lists is the fact that the measuring pressure is 3 Bar, or 43.5 lb/sq in, not 2 Bar. Also, most of the early Bosch injectors are either 265 or 380 cc/min. I've wondered what the differences really are that justify different part numbers. Hose config is one- straight vs. elbow or length thereof, but that's all I can imagine. Impedance of the coil could be another- high or low (ours are low). Color is another difference, but that hardly justifies a different part number.
http://www.telusplanet.net/%7Echichm/tech/injectors.pdfI'm using an aftermarket (Niehoff not Bosch) version of the -036. Listed as for Volvo and Mercedes 4.5L. That seems about right as the MB 4.5L engine is .56L per cylinder, vs. our .50L per cylinder, and they're both listed at 380 cc/min. The price was right at $49.99 each brand new from PartsAmerica.com .
Also, this chart projects HP/injector @ 3 Bar, which is 53HP for the smaller (265 cc) and 76HP for the larger (380 cc/min) units. That's 304HP across 4 cylinders!!!
Jim
