QUOTE(will @ Oct 8 2006, 05:48 PM)
What do you think is missing from the instructions?
hello,
after reading your instruction a couple of times, installation seems easy. I will attempt installation tomorrow.
In response to your question, "what do you think is missing from the instructions?", I think pictures or diagrams would make it a little bit better. For someone like me who hardly turns a wrench, a few more pictures or diagrams would greatly help.
thanks again,
will
Hopefully you've removed a shifter before. If not, hopefully you have a manual that I'd suggest reading first.
There is one caveat that has nothing to do with the shifter itself. On the original shifter bar where the original shifter bolts up tdo not remove the collar that's on the splined end of the shifter bar unless you mark it's placement first. It's not necessary to move/remove that collar (you should be able to figure out what I'm talking about once you get in there) which is on the splined end of the shifter bar where you will connect the rennshifter. You may have to disconnect the shifter bar in the tunnel from the shifter bar that goes to the transmission (don't remember because mine was already off). Also, when you get the shifter installed you will probably have to adjust the shifter throw using the external adjusting screws on the shifter. We did, but then again we also were using a custom external shifter bar to the transmission. By the way, it shifts like a different transmission. No comparison.
Ed aka W9R1
