LowGT
Oct 8 2006, 08:07 PM
So I have no heater plumbing or heat exchangers, but the fan shroud still has the two ports on the bottom to feed the J-tube/heat exchanger.
It seems like I would be losing a lot of head cooling air out of those holes in the fan shroud. Did you guys block those openings off, or just leave them open?
So.Cal.914
Oct 8 2006, 08:14 PM
Yes I did, I assembled the shroud and filled the holes with latex calking.
One the calking can be removed if I want to reinstall the heater and latex
calking is paintable. Backed the hole with a piece of foam to keep the calking
from falling inside. Use a wet finger to get a smooth finish on the calking.
DanT
Oct 8 2006, 08:33 PM
Blocked off with a cover plate
Not good to leave open...your motor needs all the cooling air you can give it.
Mueller
Oct 9 2006, 01:24 AM
I thought Jake or someone mentioned that simply plugging them up creates strange turbulance inside the fan housing which causes more harm than good....
possibly just have a restriction on the outlets and have it blow onto the bottom of the heads????
Aaron Cox
Oct 9 2006, 08:57 AM
QUOTE(Mueller @ Oct 9 2006, 12:24 AM)
i read that too.....
and isnt there like a vanagon shroud that has em blocked off? or omitted completely?
Borderline
Oct 9 2006, 09:05 AM
Yes, I remember Jake posting that it is better not to block them off.
bd1308
Oct 9 2006, 09:19 AM
What if you took the shroud apart and blocked them off from the inside?
that would eliminate the turbulence issue. someone here has done that, he rivited a panel over the cutout for the ducts.
