I'm in the process of buying parts to build a new motor. I would like to put a 78mm crank, 96mm pistons, raby cam.... yada yada yada. Anyway, Jerry down at NWCR is trying to sell me an EA case. Will this case be fine? Or should I try to find another code? From what I've read so far, all type 4 cases are pretty much the same, correct?
Thanks,
Rob
