Indulge me - it's been a couple weekends of great learning opportunities.
Bad news - main crank seal on my 2.7L has had a fair sized leak (like silver dollar sized spot after parking overnight) since I started using her as a daily ride about half a year ago
Good news - had a buddy and my dad up last weekend to help out
Bad news - when I pulled the tranny, pressure plate and clutch disc, the flywheel was shot - a few chipped teeth and lots fine cracking on the clutch disk surface. Pressure plate is rusted where it looks like the clutch disc seized to it at one point
Good news - PP lists early -6 flywheels as in stock for just over $400
Bad news - when you actually try to buy one, it substitutes a $700 flywheel
Good news - a google search on the flywheel part number turns up master auto parts, which has/had 4 in stock for $375
Bad news - when I pull the main seal, I find circumferential defect in the crank where the seal was
Good news - stoddard carries the correct speedisleeve.
Bad news - the requirement for all new parts makes the main seal change a 2 weekend project
Good news - I have a three day this weekend
Bad news - the correct speedisleeve is about 0.5cm too long
Good news - a sharp chisel followed by a hand file makes short work of 0.5cm of speedisleeve
Bad news - the upper bolt on the starter pulls out when I tighten it down
Good new - there are 3 more
Bad news - the opposite bolt in the lower passenger side also pulls out, making me do the right thing and repair them both today. Had to pull the dang tranny again.
Good news - Napa carries a M10x1.50 helicoil set. $45 out the door.
Bad news - 1st gear is tough to get into at a start
Good news - tranny is out, and I can R&R the gear set
Bad news - 1st gear slider is worn
Good news - Dr Evil has a good used one
Bad news - After pulling the 1st gear set, replacing the synchro and slider, 1st is still a buger to get into at a start
Good news - I had a chance to get same small tranny leaks fixed
Bad news - when I change the oil, only about 4 quarts of oil come out when I pull the line off the bottom of the tank
Good news - I have plenty of oil - throw in 8 quarts
Bad news - when I start the motor oil pukes out the tank breather
Good news - I had more than 4 quarts in the motor. Still not sure where the other 8 quarts are hiding. No way the lines and front cooler have that much (or do they).
All in all a good and typical for me couple weekends with the teener. Ended up fixing the main seal, which is good. And had a chance to get the other 911 half shaft on - now running both sides with 911 sporto tranny flange to 911 half shaft to 911 hub. Works great. Still gotta get the tranny figured out. Actually goes into 1st when shifted at the tranny - gotta be the linkage.
Now back to our regularly scheduled programming...
