Hey Everyone,
I finally decided its time to flip up the spark switch on my Megasquirt installation. I'm running MS II V.3.0 with the high current ignition driver setup triggering the negative side of a bosch blue coil. RPM signal is coming from a Pertronix hall sensor with a 1.3K pullup resistor the negative side. No R57 on the main board. Dizzy is a "frozen" 009, i glued the advance mechanism.
I wired everything up and tried cranking it tonight. Several almost starts but its misfiring. I know my advance was approx 8 degrees at idle. I tried a variety of settings but just can't get it to fire correctly. I threw a timing light on the coil and it looks like i'm getting spark.
Can someone with a similar config please post their settings?
Thanks,
Yarin
