QUOTE(bd1308 @ Oct 10 2006, 08:19 PM)
could somebody please help me figure out what they're talking about here.
http://satellite.powerbook.org/lovemb/2400/2400ioboard.htmlBritt,
I am not sure what you need to figure out from this page, but I can give you the gist of what the page says. If you need the gory details for performing the repair on a PowerBook 2400, you may need to get a literal translation.
The page deals with a PowerBook 2400 motherboard repair. The guy was troubleshooting the motherboard and power supply because of a battery problem. The initial thought was that it was a power supply issue, and a test was done for the connections and voltages which all checked out. All the smaller fuses checked out okay.
It is noted that on the back side of the battery terminal there was a surface mounted 5 amp fuse that visually appeared okay, but upon further testing, it was determined to be the problem. Because it is difficult to find a surface mounted five amp fuse, he decided to jumper in a glass tube fuse (2 amp rating). [My comments: You can see in the first four pictures the white 5 amp surface mount fuse and the yellow jumpers on each side of it. In picture seven, counting from left to right and top to bottom, there is a photo that shows the circuit board with white lettering on the motherboard that says "5A A72" which is the culprit.]
After he jumpered in the fuse, the problem was solved. He shows in the final photos the motherboard, keyboard, and AC power adapter all functional. [My comments: The display showing the battery charging is his proof of success]
Hope this helps.
Cheers,
Hoss
P.S. - In return for this Janglish translation, I would appreciate it if you could have Eric Shea send me a set of his remanufactured 914 calipers... my left rear just started leaking like a dog that found the only tree in a hundred miles.
