QUOTE(Brett W @ Oct 11 2006, 07:23 PM)
I have a 78 911 in the shop right now and after fixing a few leaks and chasing a vibration in the front wheels, I took it for a test drive. The car has bilstein struts and stock Tbars upfront. Anyway, the car seems to float and bouncy in the front. I took it up and down one of my favorite test roads and hated it. The car never felt planted, it seemed like the front end wasn't really touching the ground. It is hard to describe, maybe it is a 911 thing but it didn't feel anywhere as planted and solid as my 914.
I really don't have a lot of driving experience with driving 911s so I don't have anything to compare it to.
As others have said, you may have some suspension issues... and probably do!
But as far as perceived differences go, let's not forget that they are not the same machine...
You know in a teener when you loose control and do a spinout, the pivot point is right under your (well puckered) butt. There just isn't much weight at either end of the car to resist turning, or a change in direction, kinda like a spinning top. Even if you're just driving down the street and suddenly turn, you can still sense the effect. You are centered and at the core of the change of direction and it happens very quick. Instant transient response. It's pretty stunning.
On the other hand, the 911,(cough assdragger), has a pivoting point somewhere right around where the front headlights are... or were a moment ago before you lifted
Driving down the street and rocking the steering wheel left and right, you can feel all of that engine weight behind the rear wheels working the entire car. It's unsettling.
But it makes a very light touch to the steering effort, and it's a nice feeling. And if you keep at it, you learn to use the rear weight bias to your advantage.
But you probably have some suspension issues...
i gotta go...
