QUOTE(Brad Roberts @ Nov 7 2003, 03:49 AM)
I want to comment on these, but I dont want to piss you off.
I appreciate your comments Brad,
Since your criticisms are constructive I don't get pissed off. (actually I was hoping you would comment. Besides, you can't possibly get me as upset as when you got me onto this board for the first time.
My intent is for the box to be removable, not welded to the tubes. That way it can be easily retrofitted onto existing Super Header systems, or removed for summertime track use if desired. By sandwiching the upper half of the box between the flanges I hope it will be secure, and not rattle. The holes where the tubes go out the back have some clearance filled by a piece of ceramic batt (similar to fiberlass insulation) that is screwed down to the surface of the box. I don't want heat robbing air leaks.
I expect to make my design more sophisticated over time, both to improve performance and ease of production, but it is unlikely that the heat exchanger will ever be an integral part of my headers in the way the SSI units are made. Superior engine performance will always take precedence over creature comfort with my product.
One concern I have, which relates to a comment made on a previous topic, is the possibility of CO poisoning. I don't want to make a box that hides welded tubes permanently, just in case there was an exhaust leak. I may include a CO detector with each unit I sell, just to be safe.
One thing I haven't resolved yet is how to get the heat to both sides of the cabin. I have determined that there is pretty much no possibility of adding another box to the driver's side exhaust tubes, so all the heat will have to come from the passenger side of the engine. Can the air control valves up front be modified to redirect the warm air, or does there have to be a splitter in the engine compartment?
