I'm in Utah helping a friend set up her new house. I was gonna add a light kit to a Hunter Ceiling fan. It's normally a five to ten minute job right. Well, there is something funky with the wiring inside the fan. I've looked all over, but can't find a wiring diagram.
Here's what i see
coming from ceiling Black Wire, Black with white stripe (light kit) and white wire and a gray wire (not attached but looks like it was).
from reverse switch 2 pink wires, 2 yellow wires, grey wire (not connected, but looks like it should be and was) and white wire.
The black main wire goes to a pull switch that has these markings on it 1 2 3 L the main power is in the 2 spot and there are no other wires connected to it.
It looks like the pink & yellow are polarity for the reverse switch, easy (they're connected) the white is ground or neutral(ok, good) but WTF is the gray wire?
The switch obviously needs another connection, but I can't figure it out!!
Anyone with a diagram or inside knowledge would be most helpful.
I would be very appreciative!!!
Please call me any time tonite or early tomorrow if you can.
317 557 1257
I can call you back if long distance is a problem!!
I won't be able to check the board for a while so a phone call is necessary!
thanks, going crazy here!
