Hey all,
I'm coming back to this now that I've had some time to look into it a little bit more. Thanks everyone for your feedback. A couple points:
QUOTE(1970 Neun vierzehn @ Oct 23 2006, 02:59 PM)
Would it be safe to assume that the overflow tube connected to the tray by the gas filler neck is attached?
Yep, it's connected at both ends as it should be.
QUOTE(Mike D. @ Oct 23 2006, 03:22 PM)
the small dia hose is for the gas recerc to the charcoal canister, yours might be gone.
The hose connecting the fuel tank expansion chamber to the charcoal canister is intact.
I did a little bit of digging, and with the help of my wife was able to track down where the hose originates from (at least, where in the visual sense...I didn't actually find the other end). It disappears into the chassis ("crosswall"?), paired with a black rubber hose with a brown stripe, in the spot circled in the pic below. You can't quite see it in the picture because it's behind the _______*, but the circle indicates the location.
* And what the hell is that thing called, anyway?!? I've been trying to figure it out for an hour.
I wish I could find a labeled diagram somewhere. A collection of diagrams in the '914 Info' section sure would be useful to us novices.
Whew. Hopefully this'll be enough information for somebody to help me figure out what it is. I've read through my (new) Haynes manual and my Clymer manual form cover-to-cover and haven't had any luck.
I've learned a lot along the way though...
As always, thanks in advance!
Lava
